Group: DynoMotion Message: 6301 From: rafjawo Date: 12/21/2012
Subject: Calculate time of movement
Hi all,
I have a few questions:
1st How to estimate the time at which the motion is made​​.
System built on a stepper motor. I need to know the time before the move. Movement is initiated in the task, and it looks like this:
ch2-> Vel = 10000;
ch2-> Accel = 6E8 / / 6E8
ch2-> Jerk = 6E10;/ / 6E10;
MoveRelAtVel (2, i_data [8], (3000));
while (! CheckDone (2));
MoveRelAtVel (2-i_data [8], (3000));
I have to predict the execution time of such a movement.
2nd If I set Accel & Jerk very large e.g. 1e99. Do I receive approximately constant frequency on the output? A fixed number of pulses?
3rd sometimes when you send a command like:
moverel2 = 1
I see no movement. Axis dest looks good (1). The next command causes movement. Unfortunately I do not have an oscilloscope to see if in fact there is no pulse output. But rather, there is no pulse.
Rafal
Group: DynoMotion Message: 6305 From: Tom Kerekes Date: 12/21/2012
Subject: Re: Calculate time of movement
Hi Rafal,
#1
It is fairly complex to compute the time for a 3rd order move.  There are up to 7 "Trip States" that are 3rd order equations.
   state 1 - ramp up acceleration
   state 2 - constant acceleration
   state 3 - ramp down acceleration
   state 4 - constant velocity
   state 5 - ramp up de-acceleration
   state 6 - constant de-acceleration
   state 7 - ramp down de- acceleration
There is an internal function that computes the Trip States called:
                                                  int NoJerkControlAtStart,
                                                  int NoJerkControlAtEnd,
                                                  int Start)
This will compute the 7 sets of 3rd order coefficients and the time durations for each Trip into a list of TRIP_COEFF structures at ch->c but not execute the motion.
#2
Yes if you set the Accel and Jerk very large you will get essentially constant velocity.  You may have problems with numbers of 1e99.  But 1e12 should work.
#3
There is 1/8th of a microstep of hysteresis built into the Step/Dir Generator.  Depending on the fractional position of where you are you may need slightly more than 1 microstep of motion before a pulse is generated after a reversal in direction.
Group: DynoMotion Message: 6330 From: rafjawo Date: 12/28/2012
thanks for your answer,
But to clarify
#1
Can I you explain me parameters of this function?
From ->start position
To ->end position
MaxVel ->max velocity
CHAN *ch ->pointer to channel (ch0,ch1...)
CoeffOffset ->?????
NoJerkControlAtStart ->?????
NoJerkControlAtEnd ->?????
Start ->?????
Can I call this function in my program?
Should I calculate sum of ch0->c[n].t n(0..6) to calculate time of movement?
#2
Clear
#3
How to avoid this? I have to be sure that count of pulses are generate correctly.
Can this happen with other amount of pulses? I use it for engraving So its very important to have exactly count of pulses on output. My move is about 5 to 15. up/down. should I zeroing axis before move? then start:
MoveRelAtVel (2, i_data [8]+0.1, (3000));
MoveRelAtVel (2-i_data [8]-0.2, (3000));
Zero(2);
RJ
> Hi Rafal,
> #1
>                                                   int Start)
> #2
> #3
> HTH
> From: rafjawo <raf.jawo@...>
> Sent: Friday, December 21, 2012 2:56 AM
> Subject: [DynoMotion] Calculate time of movement
> Hi all,
> ch2-> Vel = 10000;
> moverel2 = 1
> Rafal
Group: DynoMotion Message: 6333 From: Tom Kerekes Date: 12/28/2012
Hi RJ,
CoeffOffset is the offset to begin placing the "Trips" into the "c" array.  Set to 0 to begin placing in the beginning of the array.
NoJerk...  Set to false (0) for the normal situation.  In some case back to back movements (stop followed by a reversal) are smoother faster without ramping the acceleration to zero between moves,
Start = Set to false unless you actually want the move to begin executing
Yes you can call this function in your program.  Make sure an independent motion using the same "c" array coefficients is not currently in use.
Yes sum those 7 Trip State Times to find the total time of the move.
Regarding #3: I don't fully understand the problem.  KFLOP will always command the correct number of pulses for the commanded position with 1/8th step of hysterisis.  This solves problems when moving on the exact boundary between two steps.  You can think of each "step" having a range.  For example Step position 0 has a range from -0.5 to +0.5.  So for example moving from 0.4999999 to 0.5000001 and then back to 0.499999 could cause steps forward and backward (with no time between) when there should really be no motion.  Dithering on the boundary between steps.  So if KFLOP generates a + step output on a movement from 0.4999999 to 0.5000001 a backward motion to 0.375 will be required to generate a - step output.  I suppose you could truncate all your positions to integers if you wish.
Group: DynoMotion Message: 6334 From: Tom Kerekes Date: 12/28/2012
Hi RJ,
Group: DynoMotion Message: 6336 From: rafjawo Date: 12/28/2012
So if I set Start to 1 it will generate a move? can I use it instead any move command?
#3
As I wrote before. When I use command Moverel2=1 in reverse direction i see no move. Some times everything is ok after calling few times: EnableAxisDest(Z,0.0); I always use integer position with stepper motors
Rafal J.
> Hi RJ,
> HTH
> Sent: Friday, December 28, 2012 12:07 AM
> Subject: [DynoMotion] Re: Calculate time of movement
> Hi Tom,
> But to clarify
> #1
> To ->end position
> CoeffOffset ->?????
> Start ->?????
> #2
> Clear
> #3
> Zero(2);
> RJ
> > Hi Rafal,
> > #1
> >                                                   int Start)
> > #2
> > #3
> > HTH
> > From: rafjawo <raf.jawo@>
> > Hi all,
> > ch2-> Vel = 10000;
> > moverel2 = 1
> > Rafal
Group: DynoMotion Message: 6339 From: Tom Kerekes Date: 12/29/2012
Hi Rafel,
#1 - Yes. But I thought you wanted to know the time before the move? If you are ok with starting the move then you can use the normal Move() command (which will call the SetupForMove() function).
#3 - You are correct. After looking into it I realized that the exact transition points where steps occur is indeterminate (although forever after consistant). Here is a workaround (add this where you enable your Axis).
#define AXIS 0 // the axis to enable
#define STEPGEN (chan[AXIS].OutputChan0 & 7) // determines which base Step/Dir Generator it uses
extern double ActualStepPos[NSTEPDIR];
EnableAxisDest(AXIS,0);
ActualStepPos[STEPGEN]=(FPGA(STEP_POSITION_ADD0+STEPGEN*2)&0x7f)/128.0-0.5;
This will guarantee that the step transition points are always half way between integer positions.
Sent: Friday, December 28, 2012 12:20 PM
#3
Rafal J.
--- In mailto:DynoMotion%40yahoogroups.com, Tom Kerekes <tk@...> wrote:
> Hi RJ,
> HTH
> To: mailto:DynoMotion%40yahoogroups.com
> Hi Tom,
> But to clarify
> #1
> To ->end position
> CoeffOffset ->?????
> Start ->?????
> #2
> Clear
> #3
> Zero(2);
> RJ
> > Hi Rafal,
> > #1
> >                                                   int Start)
> > #2
> > #3
> > HTH
> > Hi all,
> > 1st How to estimate the time at which the motion is made&#8203;&#8203;.
> > ch2-> Vel = 10000;
> > moverel2 = 1
> > Rafal
Group: DynoMotion Message: 6347 From: rafjawo Date: 12/29/2012
Thanks for your help.
#3 solved.
#1 I have done some tests. Here is my short program:
double myTimer;
double myTimer2;
unsigned int *i_data;
i_data=gather_buffer;
myTimer=Time_sec();
SetupForMove(0, i_data[8], i_data[9], ch2, 0,1,1,1);
myTimer2=(ch2->c[0].t+ch2->c[1].t+ch2->c[2].t+ch2->c[3].t+ch2->c[4].t+ch2->c[5].t+ch2->c[6].t)*1000000;
while(!CheckDone(2));
myTimer=Time_sec()-myTimer;
myTimer=myTimer*1000000.0;
i_data[100]=(int)myTimer;
i_data[101]=(int)myTimer2;
i_data[102]=(int)(myTimer-myTimer2);
i_data[103]=(int)(ch2->c[0].t*1000000);
i_data[104]=(int)(ch2->c[1].t*1000000);
i_data[105]=(int)(ch2->c[2].t*1000000);
i_data[106]=(int)(ch2->c[3].t*1000000);
i_data[107]=(int)(ch2->c[4].t*1000000);
i_data[108]=(int)(ch2->c[5].t*1000000);
i_data[109]=(int)(ch2->c[6].t*1000000);
I can see difference between myTimer & myTimer2. it is about 300 to 470us. Its changing when I change speed or length of move. Its constant with constant parameter
For example:
GetGatherdec8;GetGatherdec9;
10
4000
KFLOP 4.29
Ready
GetGatherdec100;GetGatherdec101;GetGatherdec102;
3239
3016
223
10
6000
KFLOP 4.29
Ready
2699
2299
400
15
500
KFLOP 4.29
Ready
30509
30182
326
I'm not sure where is delay. Before move? or CheckDone? Time_sec()?
I'm using only one user task
Rafal J
> Hi Rafel,
> HTH
> Hi Tom,
> #1
> #3
> Rafal J.
> > Hi RJ,
> > HTH
> > Hi Tom,
> > But to clarify
> > #1
> > To ->end position
> > CoeffOffset ->?????
> > Start ->?????
> > #2
> > Clear
> > #3
> > Zero(2);
> > RJ
> > > Hi Rafal,
> > > #1
> > >                                                   int Start)
> > > #2
> > > #3
> > > HTH
> > > Regards
> > > Hi all,
> > > ch2-> Vel = 10000;
> > > moverel2 = 1
> > > Regards
> > > Rafal
Group: DynoMotion Message: 6348 From: Tom Kerekes Date: 12/29/2012
Hi Rafel,
I think several hundred microseconds is within the expected uncertainty.  The Servo Sample Rate that generates the trajectory is 90us.  User Threads only execute every 180us.  The SetupForMove involves a lot of calculations to compute the 7 3rd-order polynomials.  All these add time and uncertainty to get the move started and to detect when it completes.  The motion itself should be very accurate once started and equal to the computed times.  If you nee more accurate times between moves and such you may need to use the Coordinated Motion Buffer and queue all the moves.
